banshee for sale or trade....
frame does not have a title and vin# has been powdercoated over.
here are specs:
cylinders ported by area51 offroad fresh 64.5mm bore.
new weisco pistons, rings & rod bearings.
stock stroke oem crank has been trued and welded
35mm pwk carb, stock reeds & cages
vitos bullseye billet intakes
blue noss head w/ 21cc domes
shearer inframe exhaust
fast clutch w/ heavy springs & cascade pancake bearing
engine cases have been epoxied and port matched
stock trans with modded shift shaft
modquad billet waterpump impeller
lsr +2+1 a-arms w/ dune edition elka recreationals on front
+4 round house swingarm, i think its a metal tech
g force axle and stock rear suspension components
bike needs rear brakes, stator, flywheel, timing plate, kicker and shifter
to be fully operational.
bike is located in central MS
i would like 2500 or trade for youth quad.
engine is fresh as it has only had about 6gallons of fuel thru it.
if i dont get any hits i may part out the entire bike.
Edited by Hilarious
:smile:
sorry, i should have been more specific when i said trade.
may trade for something along the lines of a raptor 80 and
some money or just money.
Edited by Hilarious
i would be interested in the pipes.
you should be able to get a decent amount out of it if you decide to part it with all the aftermarket stuff on it.
i have some t-5's and/or a set of procircuits you could put on it if you still wanted to sell it all together.
  • 2 weeks later...
