Bill Posted July 3, 2008 Report Posted July 3, 2008 Ok I got A newer style key switch(square plug)and my shee has A 89 harness, so I need to hard wire it. Now I know that I need to complete the circuit in order for it to run. There is four wires coming of the switch, the blk and the blk/wht wires show continuity and same with the red and brown.My question is does it matter what two wires I use to complete the circuit? If I use only two wires do I just tape off the other two separately? Thanks for any info, Bill Quote
spurdy Posted July 4, 2008 Report Posted July 4, 2008 Ok I got A newer style key switch(square plug)and my shee has A 89 harness, so I need to hard wire it.Now I know that I need to complete the circuit in order for it to run. There is four wires coming of the switch, the blk and the blk/wht wires show continuity and same with the red and brown.My question is does it matter what two wires I use to complete the circuit? If I use only two wires do I just tape off the other two separately? Thanks for any info, Bill Should be that the black and the black w/white go together. The other 2 are not used. SP Quote
