chiwape Posted June 30, 2008 Report Share Posted June 30, 2008 Well I looking for some feed back on steering knuckle. I race desert and just spent the day towing in my banshee due to the front steering knuckle breaking. I am wondering if any out there uses a stronger or different steering knuckle or if I need to just order any OEM steering knuckle. I really just looking for something that wont break again or will last alittle longer. Any feedback would help thanks. Also when ordering a steering knuckle it goes by left or right so is that left or right determined by standing in front of the bike or is it by seating on the seat?? Quote Link to comment Share on other sites More sharing options...
BenBB Posted June 30, 2008 Report Share Posted June 30, 2008 RH or LH as you're sitting on it. Knuckle...you mean tie rod or spindle?? I broke both, upgraded tie rods & ends to Honda-style (where the tie rod end is female thread and the tie rod itself is solid and male threaded, think I got Tusk setups from RMA), and went to YFZ450 spindles (aluminum but still has steel spindle shaft) and hubs, brake calipers, etc. Had to reinforce my steering stop with angle iron as well... Quote Link to comment Share on other sites More sharing options...
chiwape Posted July 1, 2008 Author Report Share Posted July 1, 2008 yeah its the steering spindle snaped on top next to where the tie rod bolts up. the tie rod is ok might need to get new ball joints since the rubber has torn on them. so you think the yfz 450 spindle will work instead of stock?? Quote Link to comment Share on other sites More sharing options...
