i bought a banshee and the guy told me it was bored .20 over, it now needs a piston kit, and i am not sure what size i need to buy any help will be appreciated.
I'm rebuilding mine right now and just looked at some pistons that were 64.50 and that I believe that was for a .020 over bore.
well, if there is any cylinder scoring, then you will need to go will whatever size piston that you bored the cylinders out to. if you are keeping the piston the same size, cause the cylinders are fine, then you can get some wiseco or pro-x pistons from parts unlimited or some of the sponsors on this site that are .02 oversized as well.
Edited by mopar1rules
Take it to a good machine shop and they will tell you what size pistons to buy. In my experience, my guy will bore it first then tell me what size piston to buy.
2nd that. Clean up the bore first and measure. Purchase pistons and measure them then match the cylinders to the pistons. Most guys that do the cylinder work will order the pistons and the cost is figured into the machine work. FYI 0.010" is equal to 0.25mm. Yes, 0.020" over is 64.50mm.
SP
