rawbansheepower Posted June 27, 2008 Report Posted June 27, 2008 I've never messed with d slide carbs before and having trouble... Can't figure how u get the throttle cable to stay on there or how its suppose to go ... Any advice will help thanks Quote
boneyardbanshee. Posted June 27, 2008 Report Posted June 27, 2008 in the slide there is an inset you need to slide the iner part up to expose it. then slide your spring up your cable, slide the cable end into the inset, release your spring and then slide the iner part of the slide back down to cover it all up. then you just put your tops back on. Quote
