TRO73 Posted June 26, 2008 Report Posted June 26, 2008 Does anybody know how much the timing is advanced on each of the curves on the dyna fs ignition? Quote
rb0804 Posted June 26, 2008 Report Posted June 26, 2008 go here and pick the type of box you have, download the install directions and there is a timing map for each program 1-4. 4 is stock http://www.dynaonline.com/skins/downloads/Default.aspx Quote
TRO73 Posted June 26, 2008 Author Report Posted June 26, 2008 Hey Thanks....the map on the side shows the advance "degrees" and on the chart it looks like they all start out at about 17 or 18 and then go up from there.....that dont seem right? Quote
Snopczynski Posted June 26, 2008 Report Posted June 26, 2008 1-3 are advanced, 4 is stock. Run curve 3, its the best one if you dont have a program kit. Also need to still advance your timing plate. All this depends on compression and octane though. Quote
TRO73 Posted June 26, 2008 Author Report Posted June 26, 2008 1-3 are advanced, 4 is stock. Run curve 3, its the best one if you dont have a program kit. Also need to still advance your timing plate. All this depends on compression and octane though. I'm running 20cc domes and 93 octane gas....just sent my cylinders off to get ported by Kevin Quote
Snopczynski Posted June 26, 2008 Report Posted June 26, 2008 If he raises the exhaust port it will change the compression. Quote
