Hey i just bought a T-REX cylinder kit 392cc(68mm bore), with pump gas domes(not sure what size, but runs on pum gas), and a set of Kenhin 35mm PWK carbs. I'm running the stock airbox with a K&N and no lid, and a set of trinity stage IV pipes. I live in canada and am right around sea level. I was told told by the guy i bought the cylinders off of to run 160-158 mains, 52 pilots, and CEL needles with the clip in the middle position. Dose this sound right? Also do i need to get the pingel dual petcock??
Turn the air screws all the way in untill they stop..Then back them out 1 full turn then another half turn.The idle will need to be set by ear or a sinc tool..YOu can do a search on here for both...Good luck..Lowbuckracing
