00tbanshee Posted June 17, 2008 Report Posted June 17, 2008 where is a good spot to run the timing for a 4mil cub alky setup.i have a stock ignition Quote
shanYE west Posted June 17, 2008 Report Posted June 17, 2008 most run about 7-8. I run mine about 12-13 Quote
wesw Posted June 17, 2008 Report Posted June 17, 2008 it would depend on your compression, squish velocity and band of the domes. you should be able to run 7 easy too much it will kick back and other stuff. Quote
shanYE west Posted June 17, 2008 Report Posted June 17, 2008 my compression was right around the 200 mark when I checked it last week. I'm not saying to run it at 12-13.. like Wes said.. its all in your dome configuration. Quote
dajogejr Posted June 17, 2008 Report Posted June 17, 2008 You're not going to be able to run what we do running 500 feet. I'd start it at 7-9...see how it likes it. Quote
KEVSWS6 Posted June 17, 2008 Report Posted June 17, 2008 Start at 8 and work it on up. Keep track of your MPH at the traps. Quote
00tbanshee Posted June 17, 2008 Author Report Posted June 17, 2008 ok. i got it at 6 now i believe Quote
