rb0804 Posted June 15, 2008 Report Posted June 15, 2008 would the j arm fram be better for a drag chassis? i have the option just wondering which one is better. thanks Quote
2bzy2p Posted June 15, 2008 Report Posted June 15, 2008 as far as weight yes a jarm frame is lighter then a a-arm frame. Quote
moving4ward Posted June 16, 2008 Report Posted June 16, 2008 If it's a good deal go for it. It's doubtfull you'll notice any difference. If you want to lighten the frame start by removing unused brackets. Quote
Natemills8 Posted July 11, 2008 Report Posted July 11, 2008 A stock frame is a stock frame J-Arm Or A-Arm Their Gonna weight about the same Quote
J-Madd Posted July 11, 2008 Report Posted July 11, 2008 I disagree. Any weight lost off of the frame is better for drag racing. We spend hours grinding of tabs and up tubes to lose less than 15lbs. If you can lose 1 lb (or whatever) with the J-arm frame, go with it. Quote
