endofitall9 Posted June 11, 2008 Report Share Posted June 11, 2008 (edited) ok here it is fellers..my moda are in the sig..I've been trying to fine tune this thing now for like 3 weeks..the problem is in the slow jets..I have a slight bog..if you hammer the gas it will bog but if you do that then hit it again it will take off...I started with a 45 pilot and it seemed like it was lean..the plugs had no color at all while idling and the bog was pretty bad...well long story short I am now at a 55 pilotand the bog is still there but not that bad..the plugs have a dark dark color to them now but they arn't wet..it has me all confused..My top pulls great and plugs look perfect but now ever since I put the 55 pilot in there it has aslight brek up in mid range..(I'm going to lean the needle out and see if this helps...) I just dont know what to do keep going bigger on the pilots or could there be something else wrong..comp is at 145 each cylinder it usually takes about 3 kicks to start and thats weird because with my stockers and same mods it started up on 1st kick...also I have no airleaks or other leaks of the sort..it has to be carbs...any recommendations? Also the airscrew is 1 turn out and I can let it sit there and idle all day and it wont load at all....but c'mon a 55 pilot on my motor? Edited June 11, 2008 by endofitall9 Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 11, 2008 Report Share Posted June 11, 2008 What needle are you using? Quote Link to comment Share on other sites More sharing options...
endofitall9 Posted June 11, 2008 Author Report Share Posted June 11, 2008 MJN clip is currently secong spot from top..... Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 11, 2008 Report Share Posted June 11, 2008 Ricky Stator coil, CDI and Stator? You might as well kick yourself in the balls twice.... The PWK28 carb might share the PWK moniker, but it jets nothing like the larger PWK series. I'd see what other guys are running for needles in those carbs. If you have OEM stator, coil and CDI, I'd use those and start over....electrical issues will have you chase jetting all day long to no avail... Quote Link to comment Share on other sites More sharing options...
endofitall9 Posted June 11, 2008 Author Report Share Posted June 11, 2008 see..i can throw my stock carbs on there and it run perfect with no issues..then switch over to these carbs then i start having issues..it is mainly in the slow jet I'm thinking by the time, I'm done I'll have a 60 pilot in there just to get it to run right with these carbs..but yeah daj I dont think it is electrical on this one... Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 11, 2008 Report Share Posted June 11, 2008 (edited) When I had my 28 pwks I think I was using JJL's or JJK's.. The needle diameter will bleed over into the slow circuit jetting. If everything else is seeming fine.. maybe a MLL? Edited June 11, 2008 by Fouledout421 Quote Link to comment Share on other sites More sharing options...
endofitall9 Posted June 11, 2008 Author Report Share Posted June 11, 2008 so..i went to the sudco needle charts and MJN is the richest needle, I believe so what would be a suggestion should I raise the needle? and see if that help also i see if i cant get a video up this evening of what it is doing.... Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 11, 2008 Report Share Posted June 11, 2008 Re-read that chart. It has a lean taper. It has a rich L1 length, and has a lean overall length... Quote Link to comment Share on other sites More sharing options...
endofitall9 Posted June 11, 2008 Author Report Share Posted June 11, 2008 my bad i guess i was reading it wrong..I'm an idiot..so that would mean that i woul dhave to be big on my slow jet correct..because thats what i headed toward lol,....... Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 11, 2008 Report Share Posted June 11, 2008 Those charts are confusing as all hell...don't feel bad at all. I had to sit there and decipher it for 10 minutes...LOL. Get one of the needles fouledout suggested. Quote Link to comment Share on other sites More sharing options...
endofitall9 Posted June 11, 2008 Author Report Share Posted June 11, 2008 yeah I'll see if i can get my local shop to order me some JJK needles and start all over lol...I now have 2 of every pilot from a 35 to a 58..lol thats $100 in jets..lol I'll see what my buddy has in his 35s and see if i can get it dialed in with those before i buy some..don't want to waste anymore money........ Quote Link to comment Share on other sites More sharing options...
endofitall9 Posted June 11, 2008 Author Report Share Posted June 11, 2008 anyone know if that will work can i use needles from 35 pwks in my 28 pwks..? Quote Link to comment Share on other sites More sharing options...
JKJK Posted June 11, 2008 Report Share Posted June 11, 2008 No ,the needles from the larger carbs won't work.JJH or JKH is what i would recommend.On my 4 mill mx port the JJH's worked great,but JKH would of been optimum for my application.This was with 48 pilots,162-165 mains,1 1/4 turns out on the air screws,1st or 2nd clip down. Sea level,65deg. Quote Link to comment Share on other sites More sharing options...
endofitall9 Posted June 11, 2008 Author Report Share Posted June 11, 2008 alright yeah i think im going to have to pick up some jjh needles ill try them and if i can get it to my liking with them that'll be fine but if not I'll keep trying thanks for all the help guys..now for the real question....does anyone have some keihin JJH needles they would want to get rid of? Quote Link to comment Share on other sites More sharing options...
ratman Posted June 12, 2008 Report Share Posted June 12, 2008 i feel for ya, 3 weeks of playin myself, 4 mm stroke, long rod, 28pwks. Im at a 45 pilot and 155 mains, currently waiting for some needles i ordered and the jjh is one of my selections. n68a is what ive been told works well in the 28pwk. Carb parts warehouse seems to stock a lot, im in canada and i couldnt find anywhere for needles up here. Keep posted how things work out Quote Link to comment Share on other sites More sharing options...
