:down: First of all I would like to apologize if this question has already been answered... tho I don't thread often I am no newb but have a sh*t computer and don't have time to search much.... second you guys are usually good help to the people with problems on here... everynow and then there is a tard who wants to argue with every one but Im hopin i get some goodness too!! lol, :cool: first off its the 01 shee with fmf fatties boost bottle and Keihen flat slides... wiseco standard pistons.. k have no compression tester but plenty of compression to pop my finger off... as the book puts it... won't start for shit takes 20 kicks if I can even keep kicking it or if i pull it when it starts right side doesn't seem to be running well no smoke from the right pipe and back fires every so often but I know the piston is cool i just put the new ones in like 3 months ago i have spark... oh and I have a ricky stator with adjustable plate.... umm I think its the carbs no clue what size the jets are how to tell how to change how to adjust don't know sh*t about carbs... I don't want a four poke but honestly RUN DAMN IT
thanks guys
Colin
Sounds like dirty carbs,but could be alot of other things.Take those carbs off take them apart and give them a good cleaning.
Couldnt really understand everything you said. But ive seen 4 things so far that will make a banshee backfire...
1. Dirty carbs.
2. bad Stator.
3.sheared flywheel key.
4. Jetting is too lean.
I had the same problem. Only one side would run and it would backfire like crazy. My problem was a bad stator. Switch your plug wires and see if the right side starts running good or it stays the same then get back to us.
alright man... Ill take the carbs off and clean the hell out of them... I don't really know how to make sure the jets are clean tho??? oh and switched the plug wires around and it was all the same...
