  • 1 month later...
I believe it would become richer if you removed the spacers and were jetted perfect prior to the removal wouldnt it?
If the shee has reed spacers and is jetted perfect, how will removing the spacers effect the jetting, leaner or richer, thanks for any info.
I was told the spacers dont make much difference performance wise. Take 'em off and sell 'em or something.
I have no idea, but I'd guess it would become a bit richer. At least in theory I'd believe that.
i'm pretty sure it would become leaner, if the reed spacers are removed. when i put reed spacers on my shee, i noticed it got real rich on top end. think about it, putting reed spacers on, pulls the reed assemblies out of the intake more, thus opening up the boost port more, letting more air/fuel get up into the cylinder. so, when you take the reed spacers out, the reed assemblies are going to move into the intakes that much more, and start to block off the boost port, thus letting less air/fuel in through that port.
