cornfed396
About cornfed396
  • Birthday 01/01/1983
Contact Methods
  • Website URL
    http://
  • ICQ
    Southwest Michigan
    Black 2006 SE, Vito's Kit-Hemi-Head-Ported-Delta VF3's, AC Propegs, DG Bumper, ITP GNCC's, T5's
cornfed396's Achievements
  1. I have a 2006 limited editon black Banshee for sale, its got Dale Sr. graphics, it has a one of kind look to it, Its got Vitos internals and a Vitos hemi head, Toomey T-5 Pipes, compression is 180 in each cylinder, jugs have nice port work done to them, V-Force 3 Reeds, GNCC tires on ITP T-9 Wheels, AC Pro Pegs, front bumper, K&N powerlid and innerbox filter both with outerwears, yamaha shock covers, full length frame skid plate. It screams, I climbed coal hill in Trevorton PA, Its never been rolled or crashed, plastic and everthing is perfect, not much ride time on it. Asking $3999 obo, text james at 269-214-8259. Located in SW Michigan. If the pics dont post send me a text and I will send u some pics if u like. There are pics on craigslist to, southwest mi .
  2. If the shee has reed spacers and is jetted perfect, how will removing the spacers effect the jetting, leaner or richer, thanks for any info.
  3. hey try a set of new plugs, and tell us how the old ones look,
  4. I had the same problem with my rincon, the more you flow out the more you need in. so i went and bought some jets from a local shop and got it tuned in. took the dyno jet kit back.
  5. Thanks for the info
  6. ya but I ride from dirt to sand and then back to dirt to get home. Some real big sand hills too. I have the HD's on now, and think I want to go to the 21" GNCC, cause they are 11" wide. Thanks for the info.
  7. anybody know which tire is better in sand between the itp holeshot HD and new GNCC.
  8. cold comp check WOT first, then ride, then hot comp check. Should the hot test be higher or lower comp.
  9. Ok, I wasn't sure but now I am. Thanks guys
  10. I just got some new vf3 reeds and was woundering whats the deal with the removable piece. Should it be removed or left in place. Seems like the engine would flow better or maybe more with it removed. Any info would be great,,,,,,,,,,,, thanks.
  11. Hey I have stock carbs on my shee, engine has a vitos kit in it, vforce3's, mild porting, hemi head. would it be good to go some 30mm D slide carbs. IF not what carbs would be better.
  12. well i guess i will stick with what i got. stock air box with k&n powerlid and k&n filter. with both pre chargers.
  13. thanks for the info, just wanted to be sure.
  14. Hey I am looking at getting a rear swingarm skid plate and need to know which one will allow the most room for a bigger rear sprocket. I currently run a 43 tooth and its real tight with stock skid. any help would be great.
  15. Hey just wondering if anybody has tried the new 2 into 1 air intake system from toomey. If so, is it worth getting. and where or how did you mount your radiator overflow tank.
