banshee404 Posted June 4, 2008 Report Posted June 4, 2008 ive seen many pictures of banshees with inversed front rims for better stability i did tht on mine and it seems the valve stem hits my caliper is there a way to fix this Quote
pabansheematt Posted June 4, 2008 Report Posted June 4, 2008 ive seen many pictures of banshees with inversed front rims for better stability i did tht on mine and it seems the valve stem hits my caliper is there a way to fix this plug the holes and drill new ones on the opposite side. Quote
banshee404 Posted June 4, 2008 Author Report Posted June 4, 2008 wht do i plug them with caz i dont got a welder Quote
shee rips Posted June 5, 2008 Report Posted June 5, 2008 use a valve stem. just put it in upside down, like with the part you put air in pointing inside the tire. Quote
gregrob Posted June 5, 2008 Report Posted June 5, 2008 If you can't figure it out you really don't have any business doing it. You'll probably just hurt yourself Quote
