How about cool heads? Does it really make a difference or is it mainly for cooling.
Thanks for the info fellas!
You may get a slight difference in temperature, but the main advantage is it enables you to change domes to increase your compression. This does make a big difference in power.
How do you like your domes.... is it a big job getting those on?
Thanks.....
Thanks.....
Well, when you order a coolhead you'll need to choose domes to go in it. It's not too hard to install it. I use the 21cc domes to stay on pumpgas. You can use the search to view alot of threads about them and see if you might be interested in getting one. I use a Nosshead and I'm very happy with it.
