testement Posted May 21, 2008 Report Posted May 21, 2008 HI GUYS BEAR WITH ME NEW AT THIS. I JUST GOT A NEW CLUTCH ABOUT 20-25 HRS AGO AND NOW THIS ONE IS GONE. MY MECHANIC SAID I MUST OF BEEN HAMMERING ON IT AND HE PUT BARNET BASKETS ON IT. I HAVE ONLY RODE IT FIVE TIMES SINCE I BOUGHT IT AND HAVE HAD HIM FIX MY BIKE WHEN BROKE DOWN 2 TIMES SINCE I BOUGHT IT. A CLUTCH 1ST TIME AND A NEW INGINE REBUILD W/ PORT WORK SECOND. IT IS GETTING EXPENSIVE AND KINDA WANTED TO DO THIS CLUTCH MYSELF. CAN ANYONE HELP ME WITH THAT I DONT KNOW HOW TO PUT IN A CLUTCH BUT SURE I CAN LEARN. OR SHOULD I GO SPEND ANOTHER 300-350 ON HIM I ALREADY PUT 1000 IN TO REPAIRS ALONE. HELP WOULD BE GREAT! Quote
dajogejr Posted May 21, 2008 Report Posted May 21, 2008 Get a clymers manual (30 bucks or cheaper) and do it yourself. Pickup a clutch kit from Jeff @ FAST. 90 bucks or so...it'll last a long time. He can also walk you through checking the rest of the clutch components. If you have worn inner and outer hubs, a new clutch won't last long...and the inner hub and pressure plate are CHEAP...like 50 bucks or something... And please turn your caps lock off... Quote
testement Posted May 21, 2008 Author Report Posted May 21, 2008 (edited) Get a clymers manual (30 bucks or cheaper) and do it yourself.Pickup a clutch kit from Jeff @ FAST. 90 bucks or so...it'll last a long time. He can also walk you through checking the rest of the clutch components. If you have worn inner and outer hubs, a new clutch won't last long...and the inner hub and pressure plate are CHEAP...like 50 bucks or something... And please turn your caps lock off... THANKS I AM KINDA NEW HOW DO I GET AHOLD OF JEFF @ FAST? Edited May 21, 2008 by testement Quote
gregrob Posted May 21, 2008 Report Posted May 21, 2008 I would get a tusk kit from rockymountainatv.com Get the "heavy duty kit" 46 bucks, use 3 of the heavy duty springs they send you and 3 of your stock ones. Changing the clutch is very simple. Should take you about 20-30minutes. Quote
banshee(911) Posted May 21, 2008 Report Posted May 21, 2008 I would get a tusk kit from rockymountainatv.com Get the "heavy duty kit" 46 bucks, use 3 of the heavy duty springs they send you and 3 of your stock ones. Changing the clutch is very simple. Should take you about 20-30minutes. i thought you had to soak your new fibers over night in oil Quote
gregrob Posted May 21, 2008 Report Posted May 21, 2008 True, I should have said the "installation" should take 20-30 minutes. You should soak the clutch fibers in your choice of trans oil for at least 4-5hrs., Quote
