JasonsBanshee Posted May 9, 2008 Report Posted May 9, 2008 How's the swingarm skidplate? How much shipped to 45036? Quote
f4istunna Posted May 9, 2008 Author Report Posted May 9, 2008 swing arm skid is in good shape Graydon proline $45 w/ shipping sound good? Ill snap some pics of it tomorrow for you if you want. I have to dbl check to see what model the reeds are. Ill do that in the morning too. Quote
f4istunna Posted May 9, 2008 Author Report Posted May 9, 2008 Got pics of most of the parts would have had more but had to come in to charge the batts. I tried to upload a few but its saying i used all my attachment space???? anyway i can clear that? either way i can just email pics to those that are interested Thanks Quote
f4istunna Posted May 9, 2008 Author Report Posted May 9, 2008 Heres a list of parts I have. Price are plus shipping if needed. I accept paypal and Money orders. Everything will be on ebay next week. Engine parts Cases good shape no damage $110 tranny and all internal gears, shift mechanisms etc $110 Oem crank and rods good shape $60 Oem crank needs one lower rod bearing/rebuilt $10 Oem head some buildup on one dome could use cleaned up $15 Cylinders not sure bore ill check on calipers tonight $100 could use hone Suspension Front stock shocks purple/pink springs $25 pair rear shock yellow spring nice shape $45 Oem swingarm $25 A arms good balljoints/boots w/ hardware Oem $90 set of 4 Tie rods w/ ends $25 pair Spindles $30 pair Oem carrier and axle $75 rear linkage $10 wheels, brakes etc... Oem white yamaha wheels 10" front 9" rear $50 for 2 or $85 for all 4 good shape normal wear ITP wheels like new $100 per 2 or $160 all 4 Complete front brake setup, master, calipers, lines etc $35 Rear master, line, resi, lever $25 Oem steering stem w/ 7/8th clamps $30 Front hubs and rotors $40 Rear wheel hubs $30 Footpegs $5 Stock heelguards metal and black plastic peices $25 Graydon pro line polished nerfs w/ hardware $65 Graydon proline swingarm skid w/ hardware $35 PRM belly skid w/ hardware $35 A arm skids (coveres top and bottom (2 peices each side)) w/ hardware $35 Blue Tag 7/8th bars w/ pad $10 V force reed valves $75 (not sure which model) Clutch lever assembly w/ cable $10 DG front bumper $30 Pro circuit platinum pipes and pro circuit silencers $180 Complete wire harness w/ components (cdi, coil, etc) $45 Headlight/kill switch $20 Oem airbox w/ filter $20 Carbs tors removed w/ twist throttle and cable $50 Radiator w/ hoses and overflow $45 Gas tank w/ cap and petcock $20 Grab bar w/ taillight $20 White headlights w/ grills $25 Stock bumper $10 Local pickup or meet w/in a few hundred miles of NE ohio Frame w/ swingarm $200 good shape no cracks, bends etc White oem plastic full fender uncut very good shape $100 Blue/white CEET seat $45 Quote
f4istunna Posted May 10, 2008 Author Report Posted May 10, 2008 Replied.... anyone know why i cant post pics??? It says attachment space used 793 of 768. I havent posted pics for months on here, is there a way to clear them so i can post pics for you guys?? Quote
Guest banshee 9531 Posted May 10, 2008 Report Posted May 10, 2008 interested in the head, what would be shipping to 52302 Quote
f4istunna Posted May 10, 2008 Author Report Posted May 10, 2008 Shipping shouldnt be more than $10 on the head. shoot me a pm if you want my paypal info thanks Quote
4smoke20 Posted May 10, 2008 Report Posted May 10, 2008 can i get pics of the white plastics? also how much shipped to indianapolis indiana 46234? thanks alot Quote
f4istunna Posted May 11, 2008 Author Report Posted May 11, 2008 pms replied Im going to try and avoid shipping the plastics if i can. I just sent a set out the other day and lost out pretty bad on them (ups backcharged me) ended up paying the guy to buy them lol Quote
