Just want to see if any of you have run into this before.
Bought a new Pro Armor rear swing arm skid plate off of e-bay from a dealer. It still has the sticker on it marked for a Banshee.
Hold it in your hand and it looks like it would bolt right up. But, try to put it on, not going to happen. It won't fit.
The parts that run vertical that you would bolt on don't fit between the mounts on the swing arm. If you kind of line up the front bolt holes, the rear mounting holes are like a couple of inches to far back. The chain guide has to come to get it even close and then the lower suspsion link starts to hit the plate and it would rub the chain so bad that I think it would eat right through the plate in no time flat.
Any of you run into this problem with a Pro Armor skid plate before? It is like it is close, but not close enough. Maybe it was made wrong or labled wrong? Any easy mounting cures for this if you have run into this before?
I have sent an e-mail to the seller to see if I can return it but I have not heard back yet.
