I went to go take a look at my stock axle because I need to remove it to put on this new durablue axle I got for dirt cheap. I don't even know where to start?
Any tips are greatly appreciated and any tools you think I will need. Also any parts I need to replace while it's apart
Thanks, Steven
First things first. I recommend you break loose the axle lock nuts before you remove the chain and tires. It can be an utter pain in the ass if you don't. next take both hubs off tires included. Loosen the lock nuts all the way and slide them off the end of the axle. Remove the chain and sprocket hub. After that the axle should slide on out of the carrier. im not good at this so hopefully itll help some.
