leadsled01 Posted April 29, 2008 Report Posted April 29, 2008 My all stock 1987 shee takes at least 10-15 minutes to warm up. It also seems to smoke more than other shees. Plugs seem alittle discolored (blackish). Should I move the "c" clips up a notch to lean it out alittle more??? Or am I way off base here??? Quote
mopar1rules Posted May 3, 2008 Report Posted May 3, 2008 is your jetting all stock? was is your oil mix ratio? if it doesn't foul plugs and runs good, who cares if it smokes and runs a little rich? Quote
jharader Posted May 3, 2008 Report Posted May 3, 2008 yup run some castor 927 and let it smoke lol smells like heaven :biggrin: that will lean it out through the midrange not your top though, mix your oil a little thinner, factory jetting is usually way rich and if u mix ur oil to what the recomend the motor will last 5 years lol Quote
