well i just got the motor running right and went out for a ride sat night. i hit a wash out and nose dived in, about a two foot hole with some big a$$ rock in the bottom of it. now my lowwer a arm is bent and it broke the bolt holes out. has any one tryed to fix this, or is it just time for a new frame? thanks robbie
Well, if you know how or have a friend that knows how to weld just weld some new mounts on.
Just like how guys do the J-arm to A-arm conversion do it :beer:
do you know where to get them? i thought about just welding washers there to help
i am a little confused. Did your frame break or did your a arm break?
Im pretty sure he is saying the mounts where the lower a-arms go through.
yes savage420 you are right. i got a new set of a arms just need to fix it so i can mount them thanks
if you or anyone you know is good with metal and welding yo can fabricate new ones and weld them in place. but if your just a shade tree mechanic i wouldnt suggest this. your a arms coming off at wot 5th gear = very bad day.
Well i guess i will take it apart tonight and weld it up. thanks for the help
