hey, i ran a few search's and couldnt find the info so here goes,
what direction are the big locking nuts on the axle right turn or left turn ? will i have to heat it up to get it off ?.
any help appreciated, thanx heaps.
If you are standing at the rear, you will need to push up on the wrench to loosen the axle nuts. It's the old, "righty tighty, lefty losey" method.
thanx for that man, now to try to get this tight mofo off.
The first time I removed mine, I had to have the wife sit on the seat, and hold down on the rear brake lever. It still took a lot of effort to get the axle nuts loose. The thread goop that Yamaha used is some nasty shit.
Yeh WOW! thats tight even with heat, im gonna have to get some pipe tomorow for leverage, i didnt know the rear suspention had so much squat.
hehe shatterd dreams i really wanted this off so i could get it straightend tomorrow.
What works even better is this little motion pro axle nut wrench that i bought.
tapped on it a little with a hammer and got the nuts off. I believe its a 50mm
wrench that fits the stock axle nuts.
If the bearings in your carrier are bad and are stuck to your axle, look out.
Getting the axle nuts off is one thing. Sometimes just getting the axle out
of the carrier is another task.
Good luck. :beer:
Good luck. :beer:
i guess thats wrong with mine, i attempted to remove the axel to clean up my swinger, but the axle would not move. so my attempt failed.
i'm assuming you got the axle nuts off and tring to get it out of
the carrier? I had to get the sledge out and pound mine out of
the carrier because it had siezed to the bearings. Spray it
generously with pb blaster and put a block of wood up against
the end of the axle, to protect the treads. And wack away with
a BFH.
Don't give up that easy, it will come out eventually. Keep it lubed and keep working it.
i ended up getting my pressure washer and washing it off and painting it up. just taped up the axel and shit.
would of been alot better to get the axel out though
a BFH.
yes everything was taken off, i tryed the BFH and a block of wood trick. still a no go..
riding season is soon here, so im not going to bother with it untill i need to replace the bearings.
