CoreyReid Posted April 3, 2008 Report Posted April 3, 2008 Hi guys, looking for a place to start on my jetting. Just finishing a rebuild on an 03 that is new to me. Here's what i have so far Wiseco top end kit .020 over Boyesen carbon reeds with stock cages stock head shaved .020 DG pipes (looking for something better) k&n filter, with no lid or modified lid with outerwear stock carbs with tors removal kit Elevation 300-800 91-93 pump gas yamalube mix. I have no idea what jets are in now, but if you could help me on what would be close, it would be appreciated thanks. Quote
xXBlessedWithDeathXx Posted April 3, 2008 Report Posted April 3, 2008 I would start at 300 on the mains. as for DG pipes. they are not bad pipes. if you think different watch my videos and look for the black/flamed banshee. Quote
Screaming Yellow Zonker Posted April 3, 2008 Report Posted April 3, 2008 Hi guys, looking for a place to start on my jetting. Just finishing a rebuild on an 03 that is new to me. Here's what i have so far Wiseco top end kit .020 over Boyesen carbon reeds with stock cages stock head shaved .020 DG pipes (looking for something better) k&n filter, with no lid or modified lid with outerwear stock carbs with tors removal kit Elevation 300-800 91-93 pump gas yamalube mix. I have no idea what jets are in now, but if you could help me on what would be close, it would be appreciated thanks. When I had my old setup it was basically the same thing but no shaved head and I had compression pistons I was running 350 jets and 30 pilots. I also have different needles. this is the kit I bought. Quote
CoreyReid Posted April 3, 2008 Author Report Posted April 3, 2008 thanks for the input, but my elevation was a bit off, i mostly ride from sea level to 650. would this effect me much? Quote
