ryanf117 Posted March 25, 2008 Report Posted March 25, 2008 is there any trick to keep the gaskets in place when your putting the cool head on thanks Quote
monster_energy06 Posted March 25, 2008 Report Posted March 25, 2008 i use a bit of white grease or 2 stroke oil to help them stick on any 2 stroke engine Quote
Snopczynski Posted March 25, 2008 Report Posted March 25, 2008 I use yamaha grizzly/Rhino cvt clutch grease on them. Works like a charm. Quote
skeletor15 Posted March 27, 2008 Report Posted March 27, 2008 i work at a transmission shop we sell grease that melts a s soon as heat hits it. it is usually blue or green. works great and doesnt leak out making you think you have a oil leak. it melts clear. check your local trans shop . if they are cool they would probably put some in a ziplock and give it to you. Quote
Snopczynski Posted March 27, 2008 Report Posted March 27, 2008 I think he is talking about transgel. Quote
dajogejr Posted March 27, 2008 Report Posted March 27, 2008 i work at a transmission shop we sell grease that melts a s soon as heat hits it. it is usually blue or green. works great and doesnt leak out making you think you have a oil leak. it melts clear. check your local trans shop . if they are cool they would probably put some in a ziplock and give it to you. Really??? that's very interesting, thank you very much for that tip!!! Quote
FireHead Posted March 27, 2008 Report Posted March 27, 2008 I think he is talking about transgel. Astroglide? :ermm: Quote
