fork Posted March 23, 2008 Report Posted March 23, 2008 New mods fmf fatties, shaved head 30, 2into1 toomey air filter, and +4 timing other than that its stock I am at 500ft elev where should I start with the jetting. Thanks Quote
fork Posted March 23, 2008 Author Report Posted March 23, 2008 New mods fmf fatties, shaved head 30, 2into1 toomey air filter, and +4 timing other than that its stock I am at 500ft elev where should I start with the jetting. Thanks Do you guys think a 27.5 pilot and a 330 main would be to much to start. thanks Quote
AustinTX Posted March 25, 2008 Report Posted March 25, 2008 Do you guys think a 27.5 pilot and a 330 main would be to much to start. thanks That sounds like a pretty good starting point. You will probably have to go down on the main a couple sizes, but you definatly wont be lean starting there. The 2 into 1 filter doesn't breath as good as pods, so I would start there. Quote
fork Posted March 25, 2008 Author Report Posted March 25, 2008 That sounds like a pretty good starting point. You will probably have to go down on the main a couple sizes, but you definatly wont be lean starting there. The 2 into 1 filter doesn't breath as good as pods, so I would start there. Thanks for the reply I plan on doing plug chops but wanted to get some kind of sarting point I just didnt want to start out to lean. Thanks Quote
bansheejoel Posted March 26, 2008 Report Posted March 26, 2008 im at around 200ft above sea level and before porting with fmf's and pod air filters i was at a 25 pilot needle on 4th clip and a 340 main and it ran perfect with a nice tan plug. I would rather be a tad rich than a tad lean. You will be close with that setup Quote
fork Posted March 26, 2008 Author Report Posted March 26, 2008 im at around 200ft above sea level and before porting with fmf's and pod air filters i was at a 25 pilot needle on 4th clip and a 340 main and it ran perfect with a nice tan plug. I would rather be a tad rich than a tad lean. You will be close with that setup Thanks for the info this will help alot better then taking a wild guess at it. Thanks Quote
