FREAKSHOW Posted March 23, 2008 Report Posted March 23, 2008 Is there a way to measure float height on these carbs? Yes I know if there is fuel coming out drain, it is to high. What I am wondering is there any tricks of the trade on setting the float level with the bowl off and turning the carb upside down to deturmane if they are to high or to low?( ie a good base line that is known to work) I have been fighting an intermitant problem with fuel coming out the float overflow line and I have replaced the neadles and floats. Any advise? thank you for your help. Quote
JKJK Posted March 23, 2008 Report Posted March 23, 2008 To determine if the float system is working correctly+at what height it shuts off.Remove carb+bowl.Hold upright.Add new piece of fuel line to carb+blow into it.While manually moving float to see where it stops the flow.Adjust float tabs accordingly.Worked for me. Hope that helps. Quote
