fastLANE Posted March 22, 2008 Report Posted March 22, 2008 I have th tors delete caps on my bike and I need to tap the idle screws in. What size drill bit and tap do I need to use? Any tips are apprecited. Thanks Quote
Bansh-eman Posted March 22, 2008 Report Posted March 22, 2008 if you got a kit it should have came with the correct tap Quote
fastLANE Posted March 22, 2008 Author Report Posted March 22, 2008 if you got a kit it should have came with the correct tap well i dont have the kit. I have a set of carbs that are set up tors deleted but the are shot. The idle screw holes are striped. I have a new set of carbs that my boy gave me and they need to be tapped... Hence my question Quote
Bansh-eman Posted March 22, 2008 Report Posted March 22, 2008 do you have a tap set or are you looking at going and buying the one you need? either way take some taps and start running them in to see which one feeds. or you can take out the screw and find the thread pitch of it and match the tap. every set could be differant. you dont want to tap it and find out your screws are a differant pitch. Quote
fastLANE Posted March 22, 2008 Author Report Posted March 22, 2008 do you have a tap set or are you looking at going and buying the one you need? either way take some taps and start running them in to see which one feeds. or you can take out the screw and find the thread pitch of it and match the tap. every set could be differant. you dont want to tap it and find out your screws are a differant pitch. found out the tap is a m6 x 0.75. I dont have one of these in my tap and dye set. Anyone wanna sell the tap and drill bit that came with there tors delete caps? Or you can send them to me...I can use them...and send em back. Let me know. Thanks Quote
