would it be posible for a ring to catch the lip of the intake ports since the bridge is gone?
no like already said the rings do NOT go down that far.
The reason something like that will eat rings is because the piston skirt is no longer evenly guided through most of it's travel. :geek:
I dont think porting the "bridge" out that far will help you at all dude, the piston windows are only so big and going bigger seems like it would create a deadspot. granted if you port match the piston windows and keep it balanced! than itd be worth your time, if you dont do anything with the piston then whats the point in opening a hole that leads to a smaller hole? i say stumble, makes no sense. people go hogwild on these things when its completely un needed : :down:
