lasvegasduner Posted March 15, 2008 Report Posted March 15, 2008 Put engine into drag frame.I moved cdi and coil.Four wires from engine to cdi.The other two,black to ground and yellow unhooked. From cdi i ran orange and black to ignition coil. I have the black out of cdi grounded.What else am I doing wrong.I have tried grounding the black red wire.Everything worked when i moved the stuff. Quote
lasvegasduner Posted March 15, 2008 Author Report Posted March 15, 2008 Put engine into drag frame.I moved cdi and coil.Four wires from engine to cdi.The other two,black to ground and yellow unhooked.From cdi i ran orange and black to ignition coil. I have the black out of cdi grounded.What else am I doing wrong.I have tried grounding the black red wire.Everything worked when i moved the stuff. Bump Quote
BellicoseBanshee Posted March 16, 2008 Report Posted March 16, 2008 Put engine into drag frame.I moved cdi and coil.Four wires from engine to cdi.The other two,black to ground and yellow unhooked.From cdi i ran orange and black to ignition coil. I have the black out of cdi grounded.What else am I doing wrong.I have tried grounding the black red wire.Everything worked when i moved the stuff. What components did you eliminate? Maybe these two schematics can help you figure out where the wires need to be. If all the wires are hooked up correctly, it might be time to start shooting wires and/or testing components. Probably not much help, sorry... Banshee Electrical FAQ Quote
lasvegasduner Posted March 16, 2008 Author Report Posted March 16, 2008 What components did you eliminate? Maybe these two schematics can help you figure out where the wires need to be. If all the wires are hooked up correctly, it might be time to start shooting wires and/or testing components. Probably not much help, sorry... Banshee Electrical FAQ I eliminated everything except cdi box and ignition coil.I do not know if some of the other wires have to be grounded or not.The other wires i just put ends on them. Thanks for the reply. Quote
BellicoseBanshee Posted March 16, 2008 Report Posted March 16, 2008 I eliminated everything except cdi box and ignition coil.I do not know if some of the other wires have to be grounded or not.The other wires i just put ends on them. Thanks for the reply. According to the electrical FAQ, the B/R wire needs to be grounded for the engine to run, and when the B/W wire is grounded, the CDI kills the engine. The B/R wire is connected to the black wire when the key is eliminated. Quote
lasvegasduner Posted March 17, 2008 Author Report Posted March 17, 2008 According to the electrical FAQ, the B/R wire needs to be grounded for the engine to run, and when the B/W wire is grounded, the CDI kills the engine. The B/R wire is connected to the black wire when the key is eliminated. Thanks again Quote
BellicoseBanshee Posted March 18, 2008 Report Posted March 18, 2008 Let me know how it turns out, I am curious to find out what was wrong. :geek: Quote
