meanjoe Posted March 11, 2008 Report Posted March 11, 2008 Hey people! How is everyone today? So i'm going to cut my front dumbo ears on the shee. What do you recommend to cut them and to smooth the roughness out when done? Quote
downNdirty Posted March 11, 2008 Report Posted March 11, 2008 What you have to do is down a bottle of vodka, grab the saw and start cutting. no need to tape off the lines, you will be fine. but if do need help. i'll walk across the street and help ya buddy. Quote
meanjoe Posted March 11, 2008 Author Report Posted March 11, 2008 What you have to do is down a bottle of vodka, grab the saw and start cutting. no need to tape off the lines, you will be fine. but if do need help. i'll walk across the street and help ya buddy. I want it to look good not shitty. Thanks pal! :biggrin: Quote
downNdirty Posted March 11, 2008 Report Posted March 11, 2008 circular saw? jigsaw? wait dont ya got a chain saw? get that bitch out. lets cut them fenders Quote
KrewZer Posted March 12, 2008 Report Posted March 12, 2008 i used a dremel and i wasnt even wasted :geek: it came out ok i guess... Quote
Pardee208 Posted March 12, 2008 Report Posted March 12, 2008 I used a utility knife with tape for my guide lines. make a few passes with the knife then just pull the blade through, cuts like butter! take your time and wear some welding gloves! after removing the ears, heat up a puddy knife and melt the edges for a smoother look. :cool: Hope this helps. Quote
Pardee208 Posted March 12, 2008 Report Posted March 12, 2008 heres a pic of mine. sorry for the shitty pic Quote
roborider8 Posted March 12, 2008 Report Posted March 12, 2008 we used avariable speed dremel and cut slow and then used sand paper to smooth out the edages it work great Quote
[email protected] Posted March 13, 2008 Report Posted March 13, 2008 What you have to do is down a bottle of vodka, grab the saw and start cutting. no need to tape off the lines, you will be fine. but if do need help. i'll walk across the street and help ya buddy. you said it!! thats the only way to cut Quote
jack24piper Posted March 13, 2008 Report Posted March 13, 2008 1. the best way that i wave found is to use a jig saw and go slow. 2. Then take a high grit sand paper and smooth it down at the edges. 3.you can make a tool that can form the edges perfictly buy cutting a C in a putty knife and either heat the tool or use a heat gun with it and slide over the egdes 4. just dont press hard. brandon Quote
Twistedtrik Posted March 13, 2008 Report Posted March 13, 2008 We either use a jig saw with a metal blade ( finer cuts but go slow to keep from clogging the teeth )or an air cut off tool and then used a 1/4 sheet flat sander to smooth the edges. 400 grit works nice for this. Quote
