can someone give me a few tips on what to check because my banshee wont start i put brand new spark plugs in i tryed it with the choke on and off and same with the gas but it wont start.
Did you verify you are getting spark? Pull one of the plugs, stick it back in the cap and ground the plug against the head.. You should be able to see the spark while kicking it.
check your spark
check to see if any wires have come unplugged
try to push start it if u have spark and nothing is un plugged
make sure your kll switch in on run
sicne you changed the plugs check and see that you didnt mess the coil wires up
k i got it started thx guys appreciate the help. im not really sure what did it but i checked every thing and then after a few kicks it started right up.
