ashhat Posted March 6, 2008 Report Posted March 6, 2008 Having a problem adjusting my clutch. There is no adjustment screww in the center of the clutch. There also is no place for a screw to go. Has anyone seen one like it before cause i have no idea. If you have how would you go about adjusting it? Quote
Bansh-eman Posted March 6, 2008 Report Posted March 6, 2008 the only way that could be possible was that someone before you removed it and put a solid peice in there. it has to have something in the center that the ball and rod pushes against to push the pressure plate off the plate or you couldnt use your clutch. snap a picture and load it to www.imageshack.us Quote
ashhat Posted March 6, 2008 Author Report Posted March 6, 2008 Thanks, will get a picture loaded an a few! Quote
ClimbAnyHill Posted March 6, 2008 Report Posted March 6, 2008 Right now is the perfect time to get this clutch pusher, think I paid $55 from FAST. Quote
ashhat Posted March 6, 2008 Author Report Posted March 6, 2008 Cant seem to get the picture uploaded onto here from image shack, any suggestions Quote
ClimbAnyHill Posted March 6, 2008 Report Posted March 6, 2008 That pic is with the clutch lever pulled all they way? Looks like the rod behind the bearing but can't really tell.. If it is you should be able to push it back in & you need the bearing and clutch pusher i posted. Quote
ashhat Posted March 7, 2008 Author Report Posted March 7, 2008 This is what i pulled out of the clutch! Quote
Bansh-eman Posted March 7, 2008 Report Posted March 7, 2008 not sure what the hell that is but thats not the part you need in there... either get one from jeff at FAST or get the one from cascade. Quote
ashhat Posted March 7, 2008 Author Report Posted March 7, 2008 I had no idea what it was from the begining!!! I think i will just go the safe route and order a new one! Quote
Bansh-eman Posted March 7, 2008 Report Posted March 7, 2008 it deffinatly made for a cluch, not sure if its home made or if its from another bike, but i know its not the right one for a banshee Quote
ClimbAnyHill Posted March 8, 2008 Report Posted March 8, 2008 I have the stock parts, will ship cheap if you want them! Quote
Guest utleybanshee Posted March 9, 2008 Report Posted March 9, 2008 THAT LOOKS LIKE THE PART THE GOES INTO THE CENTER OF MY KX 250 DIRTBIKE IT DOESN'T HAVE A SCREW IN THE MIDDLE TO ADJUST IT YOU CAN ONLY DO IT FROM THE HANDLE BAR.. Quote
ClimbAnyHill Posted March 9, 2008 Report Posted March 9, 2008 And here's a diagram of the whole assembly. Which part numbers are you missing? Quote
