im really startin to get tired of the super hard clutch pull on my banshee with the 6 heavy duty springs in it
im thinking of running an 8 plate set up (1 extra plate), and just 3 standard springs and 3 heavy
do the hinson 8 plate kits run standard size banshee fibres and steels, and just use one more of each than normal? or do u have to use special plates?
has anyone machined their inner clutch hub and pressure plate to fit an extra fibre and steel into the stock set up? i thought i saw someone had done it somewhere..
thanks, mark
get an easy pull lever it will help
and 8 disk will help with holding but the springs really make the clutch.
thanks, mark
i have the full 8 plate hinson setup, they run regualr steels and fibers. just one more. if you have a pancake then the bolt will not fit with the hinson pressure plate. you will need to get a longer bolt. I have several of them that fit the Cascade/Packard panckes let me know if you need one.
