IMS Tank ( NO cap or petcock ) $150
Stock Coil $50
Lower Motor Mounts $15
Eibach 8 Inch Coil over Rear Spring 0800-225-0375, Used but good condition. $30
Brand New EK Non O-Ring Chain with Master link. Long enough for a +6. I think I counted 130 links. Brought this last year and decided to run a Sidewinder instead. $75
New Upper A Arm Bushings $25
New OEM A Arm Dust covers x4 $5
12 New Delron Bushings for A Arms $25
Marvin Shaw Spacers for Rear $5 per pair. Have 4 pairs
Stock Clutch Cover No impeller bearing, seal, or water pump cover $20
If you wish to use Paypal You add 3% for fees. If not I will take money orders.
All parts plus shipping.plus shipping.
do you know what the rear spring is set up for? weight/extended swinger/ stock shock? I was just getting ready to order one, I weigh 255.
i used to have an email from Eibach that had every spec for it but i got rid of it ALONG time ago. i'm sure you could email them the number that posted and they can sned you all the info on it.
It will fit any shock that requires an 8in spring (most atv shocks) i ran it on my +4 swinger on a works shock at 210 lbs. its was fine for me. Just keep in mind a shock isnt supposed to keep your bike from squating all the way. if your bike squats too much its more then likely your shock needs to be revalved.
The spring would help though on a stock shock right? I am contacting eibach now to check, if will fit and be a better spring rate, i will take it. thanks
Edited by cvbadass
i dont recall how long of springs the stock shock take. messure your stocker, if its 8in long then yea it will swap. i'll get you a price shipped tomorrow. shipping will probly be around 10 bucks or so. i'll get the exact amout tomorrow
Edited by Bansh-eman
Stock shock is 8" stock spring rate is 5.4 yours is 6.7 this will work for me, I just need to drop a few pounds. lol! I will pay the extra buck to pay with paypal if thats ok, I figure it would be faster, and that you could ship it to me sooner. thanks I will pm you with my address.
pm sent with all the info
