wacko2000 Posted March 5, 2008 Report Posted March 5, 2008 Hey whats up guys, I just got mine in the mail today from Jeff, I was wondering if you guys could learn me on the correct way to use this tool, to properly sync idle and slides...what has to be done first etc.....step by step.. I have heard that i was easy to use, I searched and couldnt find anything, if there is a link with directions or something, that would be kool aswell.. thanks guys, the more info/help the better.. Quote
wesw Posted March 5, 2008 Report Posted March 5, 2008 first off im going to make a video on how to do it in a week or two but first off. i think your using stock carbs if i remember correctly, you put on that adapter on the thinger. remove your air box or pods. fire the bike up. let it idle put the tool over the back of the carb, get a reading on both carbs. say 3 then 5 on the other you adjust your idle screws to where they they read the same. once you have the same reading and say your bike is running high. remember or mark the screw and turn them the same amt to bring the idle down and keep in sync. but double check after you get them to the wanted idle speed --------------------------------------------------------------------------------------------------------------------- to adjust mid throttle sync its hard to do with stock cable but get a person or something to wedge to keep the same rpms and its a bitch hard to find someone to keep a steady hand. thats why i love my terry cable just adjust the cable out and it raises the slides up. when you get a decent rpm thats not making it screaming and steady get some readings. then adjust the tops of your carbs to get the same readings. then give your cable a bit of slack and should be good to go. if you got them damn close you will be able to hear the pipes tinging at the same time. or if one is a bit quicker you know you might need to adjust them a bit more. hope this helps again ill make a video soon but got shit going on. Quote
wacko2000 Posted March 5, 2008 Author Report Posted March 5, 2008 im prob goin to print it out so I have something to refer to tom, thanks wesw.. one thing, the tool came with 2 different rubber adaptor...it actually goes over the back of the carb, i though it kinda went inside, but Im an idiot I guess.. Quote
jbooker82 Posted March 5, 2008 Report Posted March 5, 2008 Just as long as you get a good seal so the carb is pulling all the air through the gauge. For doing the mid range sync like wes said you need to keep the thumb throttle held exactly the same. Take the cover off of the thumb throttle and find a small 1/4 in drive socket to wedge between the throttle housing and lever where the cable hooks up to. That way you a good consistant reading. Quote
