all right heres the scoop, i cut off the little switch that is in the thumb throttle that is part of th TORS and it ran fine.he key under the seat and then it started acting up. What it will do is run for like ten seconds then will sound like someone is shutting the key off. It will start back up but do it again. I have no clue what to do so if anybody has any clues about what i can do please help. i put a wire nut on the TORS wire and put the key under the seat and on the kill switch the ground washer thing came off and i put a lug on it and i dont think thats it but could be. sorry i had to repeat myself when i went up to revise it it messed it up.
Thanks, Dustin
Thanks, Dustin
Its hard to understand what youre saying but Id get rid of all the wiring you dont need. Ie.. the key switch and TORS wiring, lights if you dont need them. What the hell do you need a key for? Dont say "So nobody can steal it".
Just a dumb question....but when you cut the TORS wires at the throttle did you disconnect the TORS electrical connectors from the carbs to the black box that is located under the left side of the fuel tank??
no i did not would that make a difference? and yes the gas is on
