F.BEJARANO Posted February 28, 2008 Report Posted February 28, 2008 1. Got stock carbs on my 06 with T6's, v-force 3's, Noss Head with 20's, and k&n pods, at 3000 above sea level. i keep idling high once it gets warm and goes back to normal when i pull the choke 1/2 way. got 27.5 pilots. What could be the problem? 2. My shee doesent spit out as much exhaust out of the left side as the right when idling it also sounds a little different on that side. It spits out equal amount of smoke when i rev her up but does it again once it idles. What could be my problem here? Quote
jbooker82 Posted February 28, 2008 Report Posted February 28, 2008 #1 Try turning in the air screws. #2 carbs are probably not in sync. Quote
Wildcardracing Posted February 28, 2008 Report Posted February 28, 2008 The carbs have to be synced, in other words the slides need to be adjusted so they rest a exactly the same height when in the idle position and open at exactly the same time when the throttle is applied. Use your idle adjusters to make this adjustment. Quote
