fubar Posted February 26, 2008 Report Posted February 26, 2008 ok,,im a newbe to the banshee,,it was running fine then it just stoped,,dont have any fire,,also can someone tell me how to check the coil..thanks Quote
tnr Posted February 26, 2008 Report Posted February 26, 2008 (edited) Could be loose wires. Chase all the wires down and make sure they are connected. That is a good starting point cause there are a lot of things that it could be. To check your coil you need a good ohm tester and a clymers manual. It will give you all the specs for the resistance in all the wires for the shee. Edited February 26, 2008 by tnr Quote
volcrano Posted February 28, 2008 Report Posted February 28, 2008 Could be loose wires. Chase all the wires down and make sure they are connected. That is a good starting point cause there are a lot of things that it could be. To check your coil you need a good ohm tester and a clymers manual. It will give you all the specs for the resistance in all the wires for the shee. Also-if u have tors-disconnect the wires to the brain box on the left side front-its a little black box.mine went bad-no spark.disconnect-spark.have you had stator side case off lately?flywheel off?pinched wire?wire hitting flywheel?good luck! Quote
