elwilliams13 Posted February 21, 2008 Author Report Posted February 21, 2008 What is the best way to set the floats and what measurement? I got 16mm from keihin website. Quote
Snopczynski Posted February 22, 2008 Report Posted February 22, 2008 I don't remember the measurement to use, it may be on here in the forum somewhere. I found it, read this. Float level link. Quote
elwilliams13 Posted February 22, 2008 Author Report Posted February 22, 2008 Cool will set it at 11mm. Also got some 19cc domes on the way. Spoke to my porter and said the porting lowers the compression. I am getting 125psi right now with .20 over and 21cc domes. make sense? Quote
Snopczynski Posted February 22, 2008 Report Posted February 22, 2008 Yup, I am gonna run 18cc domes, and my compression will only be 184 psi with my porting. Quote
elwilliams13 Posted February 22, 2008 Author Report Posted February 22, 2008 Sounds good will probably run some 100 octane then. Thanks for your help will update when she is all together. Quote
elwilliams13 Posted February 28, 2008 Author Report Posted February 28, 2008 Well here is the latest, Got the toomeys on waiting on the needle and jets for the PWK single. I put in 19cc domes got a TDR port and when I checked the compression I got 125 for both cylinders. A little low I think, The cylinders still had the crosshatch pattern on them. Is it necessary for this to wear down before it is broken in? Maybe I just got a bad compession gauge because it is harder to kick over than ever before. What do you think? Quote
Snopczynski Posted February 28, 2008 Report Posted February 28, 2008 you have to check the compression with a known good gauge and the motor has to be warmed up first. You also have to have the throttle wide open while kicking, and pull both spark plugs. Quote
brooklyn Posted March 3, 2008 Report Posted March 3, 2008 two words for ya dyno port great systems sound like nascar wicked low end get the 2 into 1 setup Quote
