I personally hate those magnetic drain plugs. Most of them are made of aluminum and strip out in the bottom. Not to mention its never a good idea to put an aluminum bolt into an aluminum hole.
I use the Honda gear oil, Used to change it after every weekend in the sand, have been going about every other. I usually put about 40-50 miles a day in the dunes, usually there about 3-4 days. so I guess Im going about 250-300 miles on oil now.
I use Motorex 10w30 full synthetic for use on a wet clutch I check it after every 2 hours or so and change it when starts breaking down. I never let it get black thats bad shit.
I use and trust the T.M. Designworks aluminum magnetic drain plug but you do have to be carefull putting it back in.
How do you tell when it starts breaking down?
