I got a mod quad coolhead off a guy on planet sand and I bought some 21cc domes for it. When I inserted the domes (and yes they are lined up). There seems to be a gap on the top where the dome meets the head. Almost like instead of completing the circle around the dome it peaks up a little. I looked at the other side and it looks exactly the same. Just checking if this is normal b4 I install it.
How much is a little ?
When both plates and domes are assembled (without o-rings) the dome may
stick out of the base plate .003-.005 but more than that could end up being a
problem. I have seen that on every coolhead assembly I have dealt with. I think
they are designed that way to ensure that the domes are lightly pressed against
the cylinder deck.
You can hold all of the pieces together (domes up) on a bench and measure
the step with a depth mic.
Dont forget:
Because that aluminum expands and contracts with temp changes you will have
to retourque the head nuts after riding it once or twice.
oh,
i can hardly tell shit from that pic...
you are talking about the bore being out of round ?
does the dome fit in there loose or tight ?
They are supposed to be a close slip fit.
That is.... should slide out by hand with sme drag.
My guess is the guy you bought it from melted his motor down and warped
the head and had to beat the old domes out with a hammer.
You helped him buy a new head for his new build !!
You might be able to run it, a gap in that spot in most cases probably wouldnt
hurt anything, but it might be warped as you suspected.
Run it at your own risk.........you may have trouble getting it to seal everywhere.
I have gotten fucked on every purchase I have ever made over there at PS for
many $$$. It seems like those guys are all just looking for some sucker to buy
them new parts. I only do business here on the HQ now, and am still really careful
with who.
If it leaks, let me know, I have a Trinity head Ill sell cheap. Later
so long at the o-ring grooves are intact and were they should be I doubt you will have any issues. However, I would lap the shit out of it to make sure it is as flat as can be. to take it a step further, pull the cylinders and lap those surfaces as well, then measure the distance between the top and bottom sealing surfaces of the cylinders. at that point everything should be height matched, and as flat as can be. sealing should not be an issue.
