chillls Posted February 17, 2008 Report Posted February 17, 2008 need to get new o-ring for the elbow off the back of the head going to the hose the elbow to head o-ring is leaking, pulled it off & turned it over & still leaks. the new o-ring kit does not come with this kit. the o-ring is brown in color dont know if i can just use a regular r-ring from the hardware store. can you guys help me out on this? Quote
gumby6t9 Posted February 17, 2008 Report Posted February 17, 2008 Take the o-ring to an auto parts store, they can match it up for you. Quote
jbooker82 Posted February 17, 2008 Report Posted February 17, 2008 You should be able to use a regular oring. The domes are the only different ones. Quote
csrmel Posted February 18, 2008 Report Posted February 18, 2008 need to get new o-ring for the elbow off the back of the head going to the hose the elbow to head o-ring is leaking, pulled it off & turned it over & still leaks. the new o-ring kit does not come with this kit. the o-ring is brown in color dont know if i can just use a regular r-ring from the hardware store. can you guys help me out on this? for that fitting you can use a stock banshee fiber gasket. there's no reason that this fitting needs to be oringed. its not bad to use an oring obviously, but its not needed. a fiber gasket works fine. Quote
