Well, I don't have much use for this any more. Was going to use it to build a fancy duner or drag bike, but changed plans. This is not a cheaply done frame. Gay stock useless mounts have all been removed. Gusseting on the A-Pillar. Fresh bearing and seals and new lock ring installed after PC for the steering stem.
The powdercoat is a $500 PC job that consists of the following: Sandblasting the frame, then a chrome PC was laid down, Then a translucent black layer was put down, then two layers of a "stardust" coat was put on, then two seperate clear coat layers were put on.
The frame still has the serial number stamped in it under the PC, and comes with the title of origin and a bill of sale.
The frame has been kept in a spare room, on a bed since it was brought home from the Powder-coater. There are absolutely no scratches or scapes on the frame whatsoever. It has been kept inside since brought home, and no parts have been bolted up to it since the PC job was done.
PC alone was $500, which is below cost for this PC job since I have a contract with a local PC guy. Frame is worth around $200 to $250 bare w/ the title. I would like to get $650 for the frame. Shipping will depend on where you are. Pickup would be preferred so we dont have to worry about anything happening in shipping.
This is a 1-off frame with a custom PC job. Would make an excellent project for a show bike, dune bike or drag bike.
I only have the two pics I took tonight handy. This frame looks absolutely amazing in direct sunlight. If anyone is seriously interested I can get pictures outside. The frame is a little dusty since its been sitting in the same spot for a few months now. I will clean it up and try and get more pictures tomarrow.
- Jared
Thought you were using it on the chicks bike?
BUMP for ya. :thumbsup:
Naw, changed minds on that one. Just going with a different frame. I'd have to kill her if she wrecked with this frame or ran into anything on it. We figured it was better to just give her a normal frame with some spraypaint to learn with. lol!
