nayr742003 Posted February 15, 2008 Report Posted February 15, 2008 okmy friend just bought a banshee that has the trinity 2 into 1 carb set up with a keihin carb on it and we cant get it to stop smoking on the one side like its not adjusted right any suggestions please help? Quote
TurboBanshee420 Posted February 15, 2008 Report Posted February 15, 2008 look for leaks, broken/missing pieces of gasket between the reeds and manifold. base gasket? head gasket? Sounds like one side is getting and extra dose of air and the other one is just along for the right. :thumbsup: Quote
peak-j Posted February 15, 2008 Report Posted February 15, 2008 You want it to smoke some, since it's a 2 stroke. Quote
rubberneck Posted February 15, 2008 Report Posted February 15, 2008 Does it happen to be the right side that is smoking? If so check the tranny fluid level. if its low you could have a bad crank seal and its sucking oil out of the trans into the right cylinder. Quote
