i started my banshee this morning and it was driving really slow. kinda like the choke was still out..
after a few hours it got its full power back but there was alot of white smoke comin out of 1 exhaust
can anyone help me with this please??
prob clutch side oil seal. Your crank case prob slowly leaked in some oil slowing your crank and slowly spun out, but vacuum and leaking will still pull it in and out your exaust causing the extra oil being burned (extra white smoke) if its your clutch side (rear brake lever side)exaust, thats most likely it.
hey i put 2 new plugs in jus der now.. its got its full power back but its still got alot of white smoke coming out of the rear break side exhaust.. can anyone tell me what this might be please
I think you have a crank seal out or searosly over mixed. most likely a crank seal tho, you may have to pull the motor and split the cases. Its really ez to split a banshee case tho.
Chevshee
yea its spittin out oil.. how would go about splitting the cases.. i dont know much about atv's as this is my first...
Which side is heavily smoking?
What does the smoke smell like? Does it smell like heavy premix (gas/premix oil)?
Does it smell like oil burning, like a car burning a lot of oil?
Or does it smell sweet, like antifreeze.
Check the level of oil in your tranny, and check the level of coolant in
the radiator.
it had been runnin on 1 cylinder for a few days. whats the chance that alot of petrol lay in that piston and its spitting out gas.. could the smoke be the gas being burnt from the piston.. it smell like gas tho..
If it smells like heavy gas and premix, you need to check the syncronzation
on your carbs and check the reeds and make sure you are getting ignition
on that cylinder before you go off tring to replace a crank seal.
But first, check bewteen the carbs and see if the choke crossover tube is in
place between them.
