dj_diablo54 Posted January 30, 2008 Report Posted January 30, 2008 Well I had the cyclinders worked and got a cool head with some new domes. I put everything back together and it starts just idles ok. once you push the gas it hesitates then just revs high and stays reved high. So what is wrong with the bike ?? Quote
BigRed350x Posted January 30, 2008 Report Posted January 30, 2008 Well I had the cyclinders worked and got a cool head with some new domes. I put everything back together and it starts just idles ok. once you push the gas it hesitates then just revs high and stays reved high. So what is wrong with the bike ?? check your jetting and clean your carbs. Also check for air leaks around all your gasket surfaces. Quote
dj_diablo54 Posted January 30, 2008 Author Report Posted January 30, 2008 check your jetting and clean your carbs. Also check for air leaks around all your gasket surfaces. Whats the best way to clean the carbs Quote
zach45 Posted January 30, 2008 Report Posted January 30, 2008 take them apart... carb cleaner... and a bottle of that air that cleans your computer keyboard.. Quote
