Yaxy Posted January 30, 2008 Report Posted January 30, 2008 (edited) Guys, I am currently running the stock needle (5DP39) on my RZshee with 28 FS Mikuni carbs. I am looking for a different taper needle that will reduce the amount of fuel off idle to about 1/2 throttle. I have adjusted the clip to postion 2 and I may move to position 1. This is an option but I am looking for suggestions on who I may be able to talk to to investigate this further. I have contacted a company who is looking further into this but at first glance there wasn't any luck. The bike runs fine the way it is and I am just looking to fine tune. With these carbs there is only one choice of throttle valve and I think there is only one size needle jet. Current low speed jetting 15 pilot jet: moving to a 17.5. With a 15 I need to have the air screws in all the way. Thanks for your time. Chris Edited January 30, 2008 by Yaxy Quote
BigRed350x Posted January 30, 2008 Report Posted January 30, 2008 Guys, I am currently running the stock needle (5DP39) on my RZshee with 28 FS Mikuni carbs. I am looking for a different taper needle that will reduce the amount of fuel off idle to about 1/2 throttle. I have adjusted the clip to postion 2 and I may move to position 1. This is an option but I am looking for suggestions on who I may be able to talk to to investigate this further. I have contacted a company who is looking further into this but at first glance there wasn't any luck. The bike runs fine the way it is and I am just looking to fine tune. With these carbs there is only one choice of throttle valve and I think there is only one size needle jet. Current low speed jetting 15 pilot jet: moving to a 17.5. With a 15 I need to have the air screws in all the way. Thanks for your time. Chris Check out sudco. Give them a call and they can help you out. - jared Quote
Yaxy Posted January 30, 2008 Author Report Posted January 30, 2008 Thanks Jared, I will look into that. Chris Quote
