ridin420 Posted January 28, 2008 Report Posted January 28, 2008 i have a k&n in box filter toomy t6's v force reeds stock engine and timing running 290 mains stock pilot air screw like 3/4 turns out it is like 0 degrees cecius i am at sea level in ontario canada bike runs not bad but bogs when i shift into six gear any sugestions on what i should be running thanks i amnew to banshees thanks :biggrin: Quote
bansheeman1988 Posted January 28, 2008 Report Posted January 28, 2008 you got the lid off that airbox? if so bump your jetting up to 340-330 and should solve your top end bog! Quote
wacko2000 Posted January 28, 2008 Report Posted January 28, 2008 Im at seal level and my old set up was similiar to you, with the exception of the T5s ad v-force reeds.. I was at 310 main and she ran great...Start around 320-330 and work down from there... Quote
