baddsheee Posted January 24, 2008 Report Posted January 24, 2008 I found a desert tank but has been cut for a pingel, can I still use my stock petcock on there? Do I have to buy a petcock to use that tank? Quote
Animalman294 Posted January 25, 2008 Report Posted January 25, 2008 You should be able to make that work, you only cut out the center between the reserve and primary holes but the bolt holes are the same and the seal sits flat on the tank. Put it on and try it. Quote
Bansh-eman Posted January 25, 2008 Report Posted January 25, 2008 yes it will wrk fine. like said they only cut the little bridge between the two tubes. just use a nice new gasket and it should seal up fine Quote
baddsheee Posted January 25, 2008 Author Report Posted January 25, 2008 Thanks alot fellas. Looks like I'll be picking up that tank. I know its going to look like Sh*t but being towed back to camp looks worse, and the sand doesn't taste to great either. :thumbsup: Quote
