socal909 Posted January 23, 2008 Report Posted January 23, 2008 this tax return im going to blow it all on the shee, on a whole new make over. starting with a new suspension. looking for shocks and a-arms setup.i mostly dune ride and drag. i was thinking on getting the ishock i5500. would like to here your guys inpute on what i should get. Quote
Bobman13 Posted January 23, 2008 Report Posted January 23, 2008 Get some Elka's if you can afford them, I've ran TCS, and Works Before and Liked them but then rode a buddies Bike with Elka Dune Series and Loved them. I-shock seem's to be good but I havn't run them But I think Work's are better for the Price to what you Get. Just My two Cents. Quote
FireHead Posted January 23, 2008 Report Posted January 23, 2008 Elka would be my frist choice, thne TCS, then Works........... Quote
RNBRAD Posted January 23, 2008 Report Posted January 23, 2008 Thing nice with works is you can specifically design the look of your shock as with the other companies you can't. Quote
Shawn G Posted January 23, 2008 Report Posted January 23, 2008 I ride mostly in Glamis. I bought Laeger LT arms, with Elka Dune Edition shocks w/resis. For the rear, I had Precision concepts revalve my shock and install a new Eibach spring. Suspension is by far the best money you can spend on your bike! Quote
socal909 Posted January 24, 2008 Author Report Posted January 24, 2008 now im leaning towards on getting the elkas. where can i get the best price and what a-arms should i get with them(laeger). should i replace the rear shock as well, does it make that much of a difference. Quote
Shawn G Posted January 24, 2008 Report Posted January 24, 2008 I got a good deal at Alba (a friend used to work there), otherwise I probably would have went elsewhere. I've noticed that Golden West Cycle/Cycle Parts West usually advertises package deals on the Laeger & Elka combos. Dirt Wheels or any other quad magazine will give you lots of options. I had my rear shock done about a year before the front suspension, and it made a huge difference. Even with a stock front, you can always better your ride using the throttle in certain situations, but only an upgraded rear will get rid of that nasty kick. I took it to Precision Concepts and just told them my weight, riding style, and where I primarily ride. I think I paid about $300 for the new spring, revalve, and seal kit (the seal kit only needs to be done the first time). Now I can revalve the shock on my own should I choose to. Plus, with the rebound and compression adjustments I can fine tune my bike for the rocks or sand. Quote
FireHead Posted January 24, 2008 Report Posted January 24, 2008 now im leaning towards on getting the elkas. where can i get the best price and what a-arms should i get with them(laeger). should i replace the rear shock as well, does it make that much of a difference. Elka has the most engineering oriented shock out of any of the mid-priced shock folks out there. :geek: Quote
RNBRAD Posted January 25, 2008 Report Posted January 25, 2008 most engineering oriented. :geek: What's that mean? Quote
Lepew Posted January 25, 2008 Report Posted January 25, 2008 I think that means, to aquaint with the practical applications of scentific and mathamatical principles. In english, more math and less trial and error? Quote
FireHead Posted January 25, 2008 Report Posted January 25, 2008 What's that mean? They actually have CAD parametized designed parts. When you call and order a shock from them, if it is outside of a general known application, they build the shock in a simulation model instead of just guess at a list of parts........... :geek: Quote
RNBRAD Posted January 26, 2008 Report Posted January 26, 2008 They actually have CAD parametized designed parts. When you call and order a shock from them, if it is outside of a general known application, they build the shock in a simulation model instead of just guess at a list of parts........... :geek: Which companies do the guessing? Quote
1.6i Posted January 26, 2008 Report Posted January 26, 2008 I had my rear shock done about a year before the front suspension, and it made a huge difference. Even with a stock front, you can always better your ride using the throttle in certain situations, but only an upgraded rear will get rid of that nasty kick. I took it to Precision Concepts and just told them my weight, riding style, and where I primarily ride. I think I paid about $300 for the new spring, revalve, and seal kit (the seal kit only needs to be done the first time). Now I can revalve the shock on my own should I choose to. Plus, with the rebound and compression adjustments I can fine tune my bike for the rocks or sand. This is what i was thinking of doing with my rear shock..,what brand spring they throw on there? Quote
Shawn G Posted January 26, 2008 Report Posted January 26, 2008 This is what i was thinking of doing with my rear shock..,what brand spring they throw on there? Eibach spring. Quote
FireHead Posted January 26, 2008 Report Posted January 26, 2008 Which companies do the guessing? Works guesses (don't let the coputerized ball valve design advertising fool you). TCS guesses, but they have always guesssed correctly as far as the stuff that I have purchased from them goes. If you by Ohlins products that were assembled in the USA, then they guess at what you need and so does Fox. Don't get me wrong, all the guessing is semi-educated, but it's hust not the same thing as what Elka or Axis (Penske) do. :geek: Quote
